Dell A920 InkJet Printer Logo
Posted on Dec 07, 2009
I cant get my dell a920 printer to work with windows 7 is there a solution? I have downloaded drivers for windows vista and then installed them have I missed something?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
232
Points
I had the same problem so I called Dell and they told me that Dell A920 isnt compatable with windows 7
2answers
Is there a windows 7 driver for the A920
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell A920 All-In-One Inkjet Printer owners thread (W7)
Remember virus programs and firewalls will block communications.
Rick
2answers
I have a dell printer A920 and an acer computer with windows 7. Having trouble getting the printer to work
First run Delete Print Jobs to remove any stuck print jobs in the queue.
Restart your computer. Make sure the printer is removed. Manual Printer Driver Removal
Download and install the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on)
Virus programs and firewalls will block communications.
Rick
Windows 7 were can i download the drivers for windows 7
Unfortunately, according to Dell's website, it looks like the A920 InkJet Printer is not compatible with Windows 7.
You could download earlier drivers for that printer from this page though (for Windows 2000, Windows XP and Vista).
My dell a920 printer won't print with windows 7
Hi There
Not no if you may have the wrong driver, this one is for Vista and most Vista drivers will work on Windows 7 gave it a go.
I have put a driver for you on my website for you it for windows Vista to download just click on the driver link and it will download for you, best to save it to your desktop so you can find it.
Link = http://www.4all2sell.com/driver/Dell-A920-Vista.exe
After you have downloaded it just double click on the icon Dell-A920-Vista.exe and follow the instructions to run the.
Please call back to say if it works for you Thanks
All The Best: Pineworks
Dell A920 with Windows Vista
Hi!
That A920 is working with vista, here is the drivers for thet:
http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PRN_ALL_A920&hidos=WW1&hidlang=en&TabIndex=
Dont forget to download and install the application to, you need all the files on that site
For that 968 printer, uninstall it, download the files from the link below and reinstall it, that will make your printer work again
http://support.dell.com/support/downloads/driverslist.aspx?os=WLH&osl=EN&catid=-1&impid=-1&servicetag=&SystemID=PRN_ALL_A968&hidos=WNT5&hidlang=en&TabIndex=
Let me know how it goes
Good luck
Nic
For a Dell A920 (Personal All-in-One), pls download OS appropriate driver(s) from here. Pls select Vista, thereafter, install.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
see if you can get a driver from dell web page that works with vista
42helpful
12answers
Believe it or not... the driver is buried on the Dell site for Vista 64-bit. I search and searched ... and there it was.
http://support.us.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R153048&formatcnt=1&libid=0&fileid=203948
In any case, I downloaded it, installed it, and it works fine. All the buttons (scan/copy) on the top work as well as printing. Now if I could just get my old XP machines to print to it on the network. But.. I think that is another thread.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
