Hello there..
If you forgot your password you need to reset the router, just remember that you need to reconfigure the router from scratch if you do reset it.
Here is how you reset the router:
Turn off the router
2.
Locate the
Reset
button on the back of
the router.
3. Use a paper clip to
press the
Reset
button and power on.
4.
Hold for about 5
seconds (don’t hold too long) and then release. (Or, release when M1 and M2
flash at the same time.)
5. After you have
completed the above steps, the router will be reset to the factory default
settings
Now you just need to log on to the router using the default admin password and username(Usually username:Admin Pasword:Admin ) and reconfigure the router and set new password.
Kind regards
Andrea
SOURCE: D-LINK ROUTER PASSWORD
you will have to reset the router to default settings by pressing on the reset button for ten seconds..all settings will be lost..read this too http://www.dlink.com/tutorial/wireless/set-password.asp and http://www.routerpasswords.com/index.asp
hope it helps!
SOURCE: forgotten dl-624+ password and cant get into settings 192.168.0.1
If you’re using Windows, go to Start > (All) Programs >Accessories > Command Prompt.
You should see a command line window. Type in ipconfig and press return. In the output you see, the IP address under ‘Default Gateway’ should be your router address.
If this doesn’t work either, or it is showing the IP address you already tried, please come back to Fixya.
There is a little hole beside the Power Plug.
This is the reset button.
You´ll need a little paper clip to press the button more then 3 seconds.
Then all in the box is resetet.
SOURCE: forgotten password for D-Link DSL G604T wireless router
These are the default settings:
When the login window appears, set the user name to Admin and leave the password box empty. If this doesn't work, you may also try admin for both username and password (all small letters).
If the default doesn't work, you may reset the password by pressing the reset button for 30 seconds. This will bring the router to factory default settings (including all the configurations set on the router).
Hope this helps.
