NorStar CallPilot 100 Logo
Posted on Dec 07, 2009
Have a Nortel Call Pilot connected to Norstar MICS 7.1 Incoming and outgoing using PRI Each phone has DID, mailboxes are setup with greetings recorded. When DID is called RNA after 4 and auto attendant company greeting answers instead of users mailbox. How do I get the mailbox to answer DID calls?
Anonymous
Level 1:
New Friend:
  • Contributor 105 Answers
  • Posted on Aug 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
105
Questions
0
Helped
41520
Points
Make sure extension is set for Call Forward/No Answer and that users mailbox is initialized.
Norstar M7310 I cannot get the greeting from the last admin off of this phone. My greeting plays when the call comes in and it directs callers to the extensions, but after my greeting the old greeting...
The greeting is from the voice mail not your phone.
Logging In To a Mailbox From Your Own Extension
1 - Feature 981
2 - Pswd: Dial 4-digit password (default is 0000)
Follow prompts to change your greeting. They are: ADMIN, then GREET and then RECORD.
When done hang up or push RLS. I have installed several of these systems.
I tried to change the password for my mailbox but now I get a message saying that the mailbox is locked. What do I do?
Are You using a Startalk180 or Norstar Call Pilot 100?
To Change Passwords you will need to go into Admin Programming in the Startalk or Call Pilot.
Voicemail ext shows "not available"
Sounds like its trying to use the default greeting using you name from the company directory. I would verify that the mailbox greeting is in place (f981>admin>greet>rec>prime>).
Can I change my MAIN Admin greeting from home if there's a storm
Depending on the type of voicemail you have It can be accomplished by calling in to the office and when the main greeting starts playing press **, the administrator mailbox number, the password and the pound key (default is 1020000). Once in the mailbox press either 9 or 99 at this point you can re record the main greeting.
6helpful
How do I remotely access voicemail messages for the Nortel T7316E?
To access your voice mail remotely, call into the voicemail and wiat for either the main greeting or your mailbox greeting to answer the line, press ** followed by your mailbox number password and then the # key (ex. **2251234#).
How do you set a ogm on a norstar phone
Dial "Feature 981" & enter your password to open your mailbox. Once you open the mailbox, you can follow the audible prompts (listed below). It's best to read from a written script. Just remember to smile - your callers will hear it in your voice.
To record an outgoing message:
1. Press "Admin" or dial 8.
2. Press "Greet" or dial 2.
3. Press "REC" or dial 1.
4. To record your primary greeting, press "PRIME" or dial 1; to record your alternate greeting, press "ALT" or dial 2; to record your personal greeting, press "PERS" or dial 3.
1helpful
How do I change my mailbox to an information mailbox?
Changing a mailbox from a subscriber mailbox to an information mailbox would require you to delete one in favor of the other but, if you want to temporarily disable the message taking ability you could login to the mailbox, press the admin key, press the greeting key, press the choose key, select alternate greeting, when you choose your alternate greeting mailbox youll be asked if your mailbox should accept messages press the chng key to toggle from yes to no. dont forget to record a alternate greeting for the mailbox.
hope that helps
85helpful
2answers
How do i set up a voice mail greeting on my nortel phone?
bodell,
The short version of getting to your greeting is:
Feature 981 or open voicemail key
your password
"8"for admin
"2" for greetings
"1" for record
"1" for primary greeting
"'1" to record your greeting
at the tone record your greeting
"#" to end recording
after you record press 1 to listen 2 to retry or # to accept
press "rls" key when finished
hope that helped.
1helpful
Rerecord the outgoing announcement
Hi, Press feature 9 8 3, display shows: Log: QUIT RETRY OK, enter system coordinator mailbox and password ( default is 102 0000 ), press OK, display shows: Admin MBOX AA OTHR, Press AA, display shows: Auto Atdt Admin GRTG TABLE LINES, Press GRTG, display shows: Greeting Admin GRTG AA, press GRTG, DISPLAY SHOWS: Greeting: RETRY OK, enter greeting number ( 1 to 20, usually 1 is the Main Greeting ), press OK, display shows: Greeting < X >, RETRY PLAY REC, press REC, at the sound of the tone record your greeting, press OK to end recording, display shows: Accept greeting? RETRY PLAY OK, press OK when you are satisfied. Good Luck
Not connecting to extensions
You have to setup the mailboxes and initialize them all before it will work properly.
Good Luck!
Top NorStar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NorStar Computer and Internet Expert? Answer questions, earn points and help others
