Ovens Logo
Posted on Dec 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does pf on digital display mean? Oven will not work
Anonymous
Level 3:
  • Master 668 Answers
  • Posted on Dec 07, 2009
Anonymous
Master
Level 3:
Answers
668
Questions
Helped
158283
Points
1894
PF means power failure.
This has caused a power outage to the oven.
This error can be removed by resetting the clock.
Hope this helps.
Thanks for using Fixya.
My oven is always flashing PF what does that mean
"PF" stands for Power Failure. There should be a reset procedure in your user's manual. I cannot specify this since you don't give the manufacturer or model number of your oven.
Jun 24, 2015 • Ovens
Kenmore ultra bake self cleaning super capacity electric oven is showing the letters pf in red what could this mean?
PF usually just refers to power failure. You should only have to reset your clock and then check to make sure everything else works.
1helpful
I have a Whirlpool Super Capacity 465 and am having issues with the following. Sometimes while baking, the oven turns off and the power to the appliance stays on, sometimes everything shuts off and PF
PF stands for power failure you are loosing incoming power power check the terminal block the control will do goofey thing with loss of voltage rule of thumb no more than a 10% voltage loss 108VAC minuim
PF code
Depending on manufacturer and model, PF can mean a number of things. On my stove, PF simply indicates "Power Fail" Yours may, too. You can clear this generally by updating the clock display. To verify that PF does indeed mean power fail for your stove, simply shut off the power for the cicuit than supplies the stove. This can be either circuit breaker or fuses. Turn the power back on after 5 or more seconds and if it displays PF again, you know it means power fail.
Otherwise, please provide the manufacturer and model of you stove for an answer.
Jul 02, 2012 • Ovens
My power went off today and when it came back on, my Kenmore oven shows error code "PF 5 AB". None of the buttons work that I press. Burners turn on, but can't turn on oven. Suggestions?
Could that be PF power failure 5AB in the Sabbath mode. That's a new one.
Your model number is useless. Sears has a big 3 digit product code followed by 8 digits.
But let me dig up my 5AB notes:
Here is what I have:
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Hope this helps
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2helpful
GE JBP45G oven display module keeps on showing ''PF'', whether I turn oven on or off.Have to constantly reset clock to make the ''PF'' message dissapear. My broiler element is not working,but why is ''PF''...
I can easily explain the "PF". It means your EOC or electronic oven control/timer is losing power for some reason, hence the "PF", for power failure.
I`d suspect the control itself is defective or at fault as they have built in transformer`s that can become faulty.
I would first insure your power supply cord is secure and in good condition in the wall or you don`t have loose wires going to the timer.
Hope that help`s move you forward, let me know if I can assist you further.
Good luck.
macmarkus :)
Feb 10, 2010 • GE Ovens
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
