Lately my m230 as well as my sister's have been acting strange. When we plug the device in it comes up as TCNAND0, which it never did before. Mine created duplicates of certain files, maybe because they were formatted differently? I deleted them, although the duplicates never appeared on my actual player. Under this TCNAND0 icon it says 492 mg, so i guess this is how much I filled up?? I should be able to fit more songs but it says there is not enough room! What happened to the other 20 mb?? I also tried using the msc format but this doesn't even show any songs. Any help is appreciated, thanks! Getting TCNAND0 error, but can't see my songs in either explorer, media player, or anywhere else. How can I delete if I can't see the files?
It's not a hard work that you can have a try powerful program Leawo Tunes Cleaner. Leawo Tunes Cleaner is a professional duplicate music remover.
Step 1. Run Tunes Cleaner and Scan Duplicate Songs
After kicking off Leawo Tunes Cleaner for Windows, click the "Clean-up Duplicates" entry. The program provides 2 duplicates scanning modes: Quick Scan mode and Deep Scan mode. Select one of them to scan duplicate songs.
Step 2. Add Music Files for Duplicates Removing
You could delete duplicate songs in iTunes music library by directly clicking "Scan iTunes" button or click "Add"button to load music files for duplicates removing. Or you could directly drag music files from your local folder to the software for duplicates removing.
Step 3. Start Deleting Duplicates
After loading source music files, click the "Scan" button on the upper-right corner to start scanning duplicates. The program would display all duplicates clearly and suggest what to remove. You could decide which duplicates to delete by checking them and then click the "Remove" button to remove duplicate songs.
For more details, check: How to Delete Duplicate Songs
If you want to delete just click on TCNAND0 icon right click then choose "format" then it will be fully free
Did that but old songs are still on the player. Nothing I've tried to delete and add new songs works.
