Mustek PVR-H160 (60 GB) Digital Media Player Logo
Posted on Dec 07, 2009
HI!I FROM GREECE! THE BATTERY OF MY MUSTEK PVR-140
HI!I FROM GREECE! THE BATTERY OF MY MUSTEK PVR-160 HAS GOT PROBLEM!I WANT TO BUY A NEW BATTERY BUT I DON'T KNOW, WHERE I CAN BUY A NEW BATTERY!THE PN OF BATTERY IS 48-090-00043! CAN YOU HELP ME?I WILL WAIT ANSWER!THANKS!
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Dec 07, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
2709
Points
25
Try the website bargain basement batteries, they carry batteries for phones, cameras and laptops and probably for media player. The other choice is to contact the manufacturer and order the replacement parts
Hi I need to replace hard drive on my Mustek PVR-H140
hi they told you to swap the hard drive but how do you copy the firmware onto the new drive windows wont let you copy the folder
Spares required.
Battery spec as per manual 1000m Ah x2 doesn't give the voltage but the charging addapter is 5volt 2.0amp.
George
1helpful
2answers
HOW TO CHANGE THE MUSTEK PVR-H140 BETTERY
It is real easy to change the battery, I have done mine a few months ago
if you remove the screws from the back top and bottom (4) and remove the case
next remove the 2 small rubber strips from each side of the hard drive, then very carefully pull the connecting ribbon off the hard drive, this can be tight so gently prise apart with a screw driver,
once the hard drive is removed you will see some earthing straps just make a note of where these are located as you will need to put them back in the right place, they simply touch the hard drive,
now you shoud see the battery (very thin in a blue plastic case) you might want to remove the rubber proctective stuff just to make it a bit easier there is a simple pull/push connector
just unplug it and replace with new battery and reverse the procedure.
Dont panic if the unit fails to switch back on as mine did when i re assembled it
it was just one of those earth straps in the wrong place.
I hope this helps,
P.S I changed the battery on a unit I bought on ebay and i had nothing to loose
if you are unsure do not attemp the repair.
NEED DRIVERS FOR MUSTEK PVR-H140
HI,
the drivers for the unit are available at http://www.nodevice.com/driver/_PVR-H140/get33981.html
you can use the unit as an external drive, you will need to connect the it to your computer via usb then power it up, after 30 seconds or so it should show up on "My Computer" as an extra drive.
if it doesn't show then the internal battery could be flat, though it will charge via the usb if the power is off (red light on when charging) or use the supplied power adapter.
G.
In my move i lost all my acessaries and instructions etc, for my PVR-A1 Personal media player
If this helps, you can download the manual from HERE
as for the accessories, you'll just have to buy new ones..
Frozen in "Initalize"
you need to go to musteks website and download the following file pvr-h140_restore_files.zip from product support area
that should get your pvr working again ?.
link to support page
http://www.mustek.com/mustek/supportdrivers.php
1helpful
Mustek PVR
Try Maplins, or a specialist electronic component supplier.
Mustek pvr h140
yeah, man, i did the same. cracked the glass, without damage to the screen, and then just made one myself, cutting it out from a cd-box and then glued it on :)
2helpful
5answers
PVR-H140 doesn't work but cannot restore files
Problem is once the hard drive is corrupted you can't access usb to fix the problem. You have to remove the four screws on the back cover remove the 40gig hard drive. Find a laptop or an ide to usb adapter to reformat the drive. Must be fat32 not ntsf. Then copy all files back onto drive.
Top Mustek Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
Music Lounge
Music Lounge
Level 1 Expert
Rick
Rick
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
