Hi Experts
During both wash and rinse programmes
Salt lamp flashes during initial fill machine fills a little more then salt lamp flashes again followed by the Inlet/Outlet lamp lighting and the prorgramme sequence display extinguishing and machine stops.
The Inlet/Outlet lamps remain on and there is at least 10mm of water above the inside filter combination.
Upon resetting and running a new sequence the machine pumps out fine.
I have reloaded the salt container and checked the salt hardness settings
I have flushed out the inlet filter within the inlet pipe connection
I have cleaned out the inner filters and non return valve.
Help required please!
Regards
Ray Baker
SOURCE: dishwasher salt
Cooking salt contains ingredients that could damage your dishwasher. It could increase water hardness and they are likely to clog when wet. Suck out as much water as you can from the salt cup,enter there dishwasher salt and run your washer few empty cycles on the lowest temperature. Good luck
SOURCE: Miele G638 CS Plus - Salt PC light flashes and will not run
have you added salt to unit?If so then you have a water intake problem or unit is oversudsing.
SOURCE: Inlet/Outlet light flashing
check your overflow level switch wich is located behind front kickplate on right hand side
SOURCE: salt for DDW1805 Danby
yes it is - salt is used to regenerate the water softener in the dishwasher
SOURCE: MY MIELE G856 SC DISHWASHER
press the start/stop and hold for 6 seconds that should clear it.
I've solved it! The Salt container has a reed switch activated by an internal magnetic float that senses a low salt level when float is low. The chamber was clagged up and the reed switch was buzzing sending false messages to the dishwasher controller.
I removed and cleaned the salt container and the float, replaced and refilled, all is now good, no salt lamp flashing anymore and cycle all good.
