I bought spd pedals and shoes and my one shoe won't snap in...but it works fine with other shoes...not sure what is going on -any ideas?
SPD hold on to cleats with a spring loaded action. This is normally adjusted with an allen key. Check that this is not screwed in so tight that action is locked up. If you don't have adjustment instructions go to shimano.com and download. You should be able to check for movement by pushing against spring clip with screwdriver (saves the fingers but mind it doesn't slip). If no movement also check for foreign body in pivot of clip. If all OK check for position of cleat in shoe. Make sure mount position is same as other shoe.
There are so many types
of pedals. I recommend that you'll get a pair that you know and you are
comfortable with. Or you can also check for reviews on pedals and take the ones
with the highest rate. However, you should remember that what's fit some people
will not necessarily fit you...
Check this link: http://www.vitalmtb.com/product/category/Flat-Pedals,20
