Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
Posted on Dec 06, 2009
External hard disk not accessible
External Hard Disk is not accessible
N: is not accessible
The file or directory is corrupted and unreadable
In properties of this drive, only 4 tabs are showing (General, Autoplay, Tools, Hardware)
security tab is not showing
How can I solve the problem????
  • Anonymous May 11, 2010
    is this a new install or existing drive?
melissazz932
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on Dec 07, 2009
melissazz932
Contributor
Level 1:
New Friend:
Answers
29
Questions
0
Helped
8943
Points
67
Usually drive N is for a network, not a drive. However, if you are sure that this is the drive, then you can right click on it and format it. This will erase everything and make it usable again.
(By the way, to test and make sure it is the correct drive, open up "my computer" and you will see all the drives listed. Try unplugging the drive and see if "N" disappears. If it does then plug it back in and format it.)
If you have data on the drive that you do not want to lose, you might be able to recover the information with a data recovery software. Here is a link that I think will be very helpful to you: http://www.roadkil.net/listing.php?Category=1
1helpful
"file or directory is corrupted and unreadable"
that happens when USB is disconnected. Might need to reinstall o/s drivers on pc or on hdd then do data recovery.
1helpful
2answers
You unplugged it when data was still written on it so it was corrupted. Some files are still recoverable so use
http://www.softpedia.com/get/System/Back-Up-and-Recovery/smart-recovery.shtml
to get them.
4helpful
2answers
connect it and do the following>
1. right click it properties and the tools and the disk check....it will remove the bad sectors it may be having.
2. if then also it doesnt work luk out for a formatting in fat 32 mode,.
cheerss...pls rate...
Problem in external hard disk
Type this command in command prompt " chkdsk /r " in specfic disk prompt (eg) f:\> chkdsk /r
Usb seagate 160 gb hard disk
Your hard-drive is crashed and unreadable by win32.dll what you can do is try kick starting by using your friend computer it just might do it. I had same problem and I asked my son to using my hard-drive on his PC. It worked and still working. good luck
About my seagate 160 gb hard drive (external)
i hav usb seagate 160 gb hard disk.nw it is nt getting open message is the file or directory is corrupted or unreadable........CHKDSK is also not working for it.error is "unable to determine volume version and start"....plz help fast
3helpful
4answers
External hard disk unreadable
2answers
2helpful
3answers
External Hard drive Failure
Seems to me like your MFT of FAT is corrupt. You can go ahead and do a format on it by right clicking and going to format. You should then be able to copy your backed-up files back onto the drive.
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
