Dremel Variable - Speed Multipro Rotary Tool 395 Logo
Posted on Dec 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Dremel tool motor still works but shaft won't turn?
Moto-tool #395 by Dremel, the motor works fine but the shaft doesn't turn.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9491
Points
23
Here's the email from I got from Dremel (in my case the flex coupling broke):
Inside the tool is a flex coupling and spline driver.
The flex coupling is # 2615294309 and the price is $ 1.25.
This is the hollow plastic sleeve about 1" long with grooves on the
inside, that goes between the motor shaft and the output shaft.
The spline driver is # 2615294308 at $ 1.00.
Spline driver sits on the direct end of the motor shaft. The flex
coupling sits over the spline driver. Spline driver is about 1/4",
hard plastic with grooves on the outside.
Total shipping for orders under $ 5.00 is $ 2.50. Orders over $
5.00 is $ 4.00.
I have provided ordering instructions below.
To order by phone: 1-800-437-3635, Monday-Friday from 7 am to 6 pm
central time. VISA, MasterCard or Discover is accepted.
To order by mail:
Dremel
4915 21st Street
Racine WI 53406
  • Darin
    Darin Jun 07, 2022
    Dremel is sending me a new flex coupling for free but the small spline driver is now discontinued. If y’all need one of those, time to buy a new tool.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 21, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9491
Points
10
The issue is a coupling - pn 2615294309- if you search on that in these posts, you will find other info as well.
Donald B Stoll
Level 3:
Guru:
  • Master 597 Answers
  • Posted on Dec 06, 2009
Donald B Stoll
Master
Level 3:
Guru:
Answers
597
Questions
0
Helped
223046
Points
1729
From looking at manual there is no transmission or connector so the only possible explanation is that the shaft is broken. You might try calling this number
1-800-437-3635 to see if they repair or can further advise you.
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Sep 26, 2010
SOURCE: dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Turn the dremel on the bit doesn't spin
My motor was turning but the flex shaft wouldn't. I took the flex shaft loose and spun it inside. Works fine now.
1helpful
Have Dremel MOD 395 motor runs and speed control works bot shaft won't turn--worth fixing ??? and how
Hi Larry, The tool that you require parts for was discontinued many years ago. Limited parts are available from Dremel. Inside the tool is a flex coupling and spline driver. The flex coupling is # 2615294309 and the price is about $ 1.25. This is the hollow plastic sleeve about 1" long with grooves on the inside, that goes between the motor shaft and the output shaft. The spline driver is # 2615294308 for about $ 1.00. Spline driver sits on the direct end of the motor shaft. The flex coupling sits over the spline driver. Spline driver is about 1/4", hard plastic with grooves on the outside. Total shipping for orders under $ 5.00 is $ 2.50. Orders over $5.00 is $ 4.00. There could be a tax charge depending on which state you live in. Here is how to order: Call Dremel Customer Service at 1-800-437-3635 , Monday-Friday from 7 am to 6 pm central time. VISA, MasterCard or Discover to place a Visa, MasterCard or Discover order. To order by mail: Dremel 4915 21st Street Racine, WI 53406 USA 1-800-437-3635 ext. 3636
Flex shaft attachment won't work
find the little square attachment and place on the end of the dremel tool. I didid the same thing. Worked fine after I put the other part on.
12helpful
3answers
Dremel moto tool model 395 coupling from motor to
6helpful
Motor works but no drive to shaft.
My 15 year old Dremel 395 had the same problem so I took it apart. There is a plastic spline between the motor and the output shaft to the chuck . My plastic spline was split and had many of its teeth sheared off. The shaft lock acts on the output shaft side of this spline, so it was ok. Otherwise everything looked great; bearings ran free & had little play free, brushes ok. To be fair, my Dremel had seen hard use & doesn't owe me anything. No luck so far finding replacement spline parts, which if available should be easy to install. To take apart your tool, just google "Dremel Disassembly". GOOD LUCK!
3helpful
Broken flex shaft on Dremel model 232 broke
You can go to Dremel.com and find assistance or call their toll free number at 1-800-437-3635 and speak with their tech assistance. Let me know if you still need more help. Also I tried using the model number provided and it came up empty that is why I am directing you to this site yourself.
Top Dremel Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
