There is no need to remove the side to replace the door seal, just behind the door seal there is a spring clip undo this and fold the seal into the drum were you should see another spring clip undo that as well and the door seal comes out from the front through the hole in the door, to refit a new fold the seal till its inside out and fitted on the inner drum first fit the inner clip then pull it through the door hole and fit the outer spring clip out side the door
It's a shot...but if I recall correctly the rubber seal thats between the door and the fridge can be peeled back or removed, and underneath are the screws that hold the inside panels on...
I would peel the seal back a little at a time until I actually locate a screw...then once located... I would feel more confident about the removal of the entire seal. Keep in mind the seal is much easier to remove than to replace...I used baby oil in some place to replace the seal...Good Luck!
