right click my computer goto properties-harware-device manager then right click the lambda click update driver browse it with ur cd driver...hope this help
All it needs is a USB connection. You'll need to go into Cubase device setup and make sure your lambda drivers are selected. Then create the audio channels in cubase with the inputs set as the inputs you're using for guitar and mic. There is a monitor button right next to the record enable button that needs to be enabled if you want to hear playback from your computer.
I'm sorry to say that there isn't a way to make bad audio good. You can sometimes make it a little better but it sounds like yours is distorted beyond help.
Your built-in microphone automatically senses how hard to "listen". Generally, being closer is better but in your case the signal was so loud that your audio sensors "clipped" the sound to protect your circuits. That means there is no signal in those gaps that could even be corrected.
The best you can do is see if someone else had a successful recording.
AFTER you open a new poject go to "Devices" then "Device Setup" click on "VST Audio System" then on he right side where it says "ASIO DRIVER" make the selection say "Lambda ASIO" then click OK
It's because when you recording your get sound from Lambda!!! But PC can't reproduce that quality! Try to download driver or update which will allow you to achieve what you want.
you need to go to the "control panel" on your computer.....click on sounds and audio devices, then hit the "audio" tab...make sure the lambda is selected on the recording and playback device....then apply...this should take care of it
