Set worked fine ,put a dvd in and watched a movie,worked fine, disconnected the dvd player after the color went bad ,no red,tried all adjustments ,can't get the same color back,but if you put a dvd in ,the color is just great.
try to put the red (or white) cable an see what is happend, try whit movie #1or2, if is not ok you must contact the service for this apliance who is in your area.
Disconnect the TV From the DVD player and Try a Stand alone Start up there might be something wrong with the DVD player and need replacing. Give this a go and let me know how to went. Ron
Depending on how it is configured to your TV it could be high contrast with the TV. One thing you might want to try is replacing the video cable if you have a spare. If you are using an RF modulator and watch DVDs on Channel 3, you might want to replace the coax line between the box and the TV set.
Solved the problem!Well, After reading two manuals on the Sony DVD player, I saw one cable not connected: the S Video connection. I connected that. Tried it out again, seemed a little better, but still not the full range of reds. At that point I thought the problem was either:
1) the cables from the DVD player to the TV
or
2) the DVD player is the problem
So, I thought I'd start with replacing the cables. Labeled them as to where they went, took them out and went to Radio Shack and explained my problem. The clerk I spoke to was very nice, said he had seen this problem before, and said there was a menu on the DVD for adjusting RGB settings.
So, I went back home, plugged in the cable, and went all thru the 2 Sony DVD booklets and the display menu on the TV. There was nothing mentioned re: color settings. Went thru the DVD menu many times, looking, looking. I felt I had come up with nothing.
Turned everything off. Turned back on. Put in a DVD: It looks great! :)
So, hoping it never happens again..cause I'm not sure I can repeat it! Maybe it was removing all the cables from their sockets and restarting...I know that sometimes works with computers...anyway..
At least I didn't have to buy a new DVD!
Lesson: unplug, re:plug...before you trash it!
M~
take a quick peek in the manual and find out where to disable the progressive scan features. may be a button on the back, or you may have to go through the on screen menu to find it. take the disc out and see if you can view what's on screen.
or since you said you had a couple of movies that did work properly, put one of those in, start the movie, go into the dvd player setup menu and disable the progressive scan settings
