I have a Lanzar amplifier, an OPTI 150. It is driving a Lanzar DC12 sub in bridged mode. The amp has blown twice, so I do not have faith in the repair capabilities of the dealer (South Africa) who sold it to me anymore. I'd like to repair it myself. 1. Info: a) I have determined that two IRF540's on the right channel (one on the push side, one on the pull side) have blown short-circuit. Having removed these, the left channel plays fine. b) I have an oscilloscope, multimeter and signal generator. 2. Questions a) Can I replace only these 2 Mosfets, or should I replace all 20 with mosfets from the same batch? b) What else do I need to check (in terms of setting variable resistors etc for proper calibration) after replacing the components?
Make sure your speaker load is correct before you blow your amp again after repairing it. I suspect that is why it keeps on blowing.
Its better to change them all. than to change 1 or 2 mosfets, bcuz simetimes it affects the other mosfets. and please check your speaker or maybe there is an resistor, capacitors, or a relay malfunctioning in that area.
