Question about M-Audio Keystation 49E 49-Key Entry-Level USB MIDI Controller with Session Recording Sof
When I hit a key, it is off by just a millisecond. How can I calibrate my m audio keyboard?
Who cares its just a millisecond and its just takes a while for it to load on the computer nobody actually counts the time it takes
Posted on Dec 07, 2009
SOURCE:
How do I fix a key that wont play on my Roland D-20
Ugh! the only way to fix this is to dismantle your D-20 to get to the bottom of the key bed. There are rubberized strips under the keys that have pads which make contact (hence, key contacts) in several places with the actual keys. The strips are attached with rubber nibs that snap into place on the base of the key bed. The reason for the lack of sound and/or the millisecond delay is a speck of dust that somehow made its way onto the contact for that key. If you decide to take this task on by yourself, make sure you clean the rubber strips (yeah I'd do all of them while you're in there) completely with canned air and contact cleaner in a dust free environment, and be sure to attach the rubber strips completely to make a dust-free barrier. Once you see the strips, the explanation will make sense. If this sounds overwhelming, take the board to a repair shop and their tech will fix this for you, as they see this issue all the time with velocity-sensitive keyboards. Good Luck!
Nov 24, 2017 | Music
Volume buttons on my toshiba laptop is not working
There are other ways to adjust the volume.
Right click on the megaphone located at the bottom right near the time. You can adjust the volume there.
Look on your keyboard and normally you can Press and Hold the FN function key located at the lower left portion of the keyboard then hit one of the 3 keys with the megaphone that adjusts the volume (1 key increases the volume, 1 key decreases the volume and 1 key mutes the volume).
You can adjust the volume in the Control Panel's audio or sound properties. Click Start/Control Panel and look for Sound or Audio.
May 04, 2012 | Computers & Internet
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
When calibrating the audio and video what does the MS mean
the MS means MilliSecond, or one one thousandth of a second
Jun 14, 2011 | Nintendo Band Hero for Wii
When I hold down a key or try to repeat a letter, it will not move without a long pause.
There is a BIOS SETUP configuration, which determines the amount of time (usually 250 milliseconds) before "auto-repeat" starts. Reboot, and enter BIOS SETUP, and configure that value.
Oct 19, 2010 | Gateway (7000864) Keyboard
When using the number pad, hitting the forward slash key gives me popup of the VIA HD Audio Deck. Hitting the minus and plus keys lower and raise the volume of my speakers respectfully. How do I turn the...
This is happening because the forward slash has been assigned as a keyboard shortcut. To fix this problem - Open HD Deck->Info->Hot key and Untick 'Enable Hot Key Function..............
Sep 18, 2010 | Computers & Internet
When I hit forward slash my audio deck comes up on the screen. When I hit hyphen, the volume shows up on the bottom of the screen. How do I correct this?
electricb921
It sound like your "CTRL" key or some other function key is stuck on your keyboard. I would try another keyboard on your computer. If the problem goes away then the problem is with your keyboard.
Issken
Jan 10, 2010 | ASUS Computers & Internet
Hi can you help ? My zebra TLP 2824 printer keeps printing out of alignment. I reset the printer by holding the feed button while powering on but instead of printing dump info the label moves for a while...
If you are using a ribbon remove it and perform a calibration, hold down feed key for 2 seconds as you power on, release key and wait for it to complete its calibration, when it has stopped shifting labels (wait for 10 secs to be sure) HIT THE FEED KEY to exit dump mode. If it has successfully calibrated it will feed a label each time you hit feed key. Re-install ribbon, make sure ribbon is pushed formly onto drive sprockets and then re-run the calibration..
If this does not fix problem. download firmware to latest version. This will automatically reset printer to factory default condition.
Nov 12, 2009 | Zebra TLP 2824 Printer
A key (which one?) changes the letters all keys type
You're hitting SHIFT and CTRL -- which changes the keyboard input method, i.e., for French keyboard, or for DVORAK keyboard, or for Scandinavian keyboard.
Access CONTROL PANEL, and use REGIONAL settings to "uninstall" all keyboard-layouts that you _never_ use.
Jul 01, 2009 | Microsoft Natural Ergonomic 4000
Lag problem - Guitar Hero / Wii / Philips 32PF5321/10 tv
Usually the video lags behind the audio. The reason is the video, in many TVs, takes longer to process than the audio coming direct from the device. To solve this, the audio needs to be delayed. This can be done by 1. Using the tv audio output. Most TVs sync the audio to the picture and this 'synced' audio is available at the output jack of the tv. 2. Delay the audio coming out of the device. Many home receivers have a 'Lipsync' feature designed for this issue. The setting is usually between 50 to 500 milliseconds of delay, depending on the TVs video processing time.
I hope this is clear and can help.
Mar 04, 2017 | Philips Televison & Video
Open Questions:
M-Audio Keystation 49E 49-Key Entry-Level USB MIDI Controller with Session Recording Sof Logo
137 people viewed this question
Top M-Audio Computers & Internet Experts
Thomas F. Schneider
John Bolton
bigdaddyd2
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
