Sharp Actius MP30 Notebook Logo
Posted on Oct 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My MP30 won't boot into Windows due to "insufficient resources". What should I do? I believe it is a disk space problem since I have been recently been receiving warning messages regarding this. I thought that I might free up space by using DirectHD, but I don't know how to do this and the laptop that I would network it with has a Vista OS.
Jesse Garza
Level 2:
  • Expert 84 Answers
  • Posted on Oct 21, 2017
Jesse Garza
Expert
Level 2:
Answers
84
Questions
0
Helped
20741
Points
254
If you computer recognizes it go to computer, right click this should show you what is recognized and locate you mp3 player files and start removing unwanted or unused files.
Level 3:
  • Sharp Master 19,187 Answers
Sharp Master
Level 3:
Answers
19187
Questions
0
Helped
4339746
Points
82259
Try booting into safemode using f8 at startup. Then see how much space you have on the hard disk
2 Related Answers
Anonymous
  • 22 Answers
  • Posted on Feb 28, 2011
SOURCE: I am getting a warning about insufficient dik
That system warning relates to available application space. For some reason Archos only devoted ~128 MB for applications, so you can fill that up pretty fast. You'll need to:
uninstall applications (settings, Applications, Manage Applications, then select and uninstall some)
or
move some applications to "internal storage", this transfers some of the space they're taking to the internal storage on your Archos. Again you'll go to Settings, Applications, then Manage Applications. From the list of applications select some of the larger ones and you may see a "move to internal storage" option. Some apps have this, some don't.
Anonymous
  • 178 Answers
  • Posted on Aug 20, 2011
SOURCE: Dell Mini 910 Laptop: Removed
hi
If you have removed all your folder then check for hidden folder if you have then erase then also ,
and clear all cookies and catches and history.
Lastly restart your system.
thanks to help you
What makes my laptop slow after booting
FIXING A SLOW COMPUTER
A slow computer could be caused by a number of things - 1. Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM. 2. Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc. 3. Uninstall/remove unused programs, this will also free up hard disk space. 4. Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it. 5. Install latest Windows updates. 6. Update virus definition files and scan computer for viruses, Trojans, malware etc. 7. Clear the Internet cache for faster browsing. 8. Hard disk maintenance is required at least once a month to keep it functioning efficiently. Run the following programs - Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space. Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
My computer won't turn on properly. It keeps saying disk error press control alt delete. When I do it just says it again and again. It won't load and turn on.
First you should check if there is any disk on your cd room, if there is any disk you should remove the disk from the cd room, if there is no disk the possibility is your hard drive getting error
Press f2 or delete to enter your bios set up system
Look for boot menu
Set the first boot as a HDD and the second boot as cd room and disable the third boot
Save and Exit the setting
if your computer still won't load you need to reinstall your windows
insert windows cd and go to set up again by pressing f2 or delete button
Set the first boot as cd room then the second boot as HDD
Save and exit the setting again
When the message press any key to boot from cd appears you should press the space bar or another key
Then just follow the instruction of formatting
2answers
Insufficient memory or disk space
just free up some disk space in your c drive
sift some data from c drive to other drives
like dektop & my document data
Blue screen and audio problem
Above error may occur due to insufficient hard disk space available for Windows XP. Make sure that you have sufficient hard disk space.
Computer BIOS might be incompatible with Windows XP or it might have to be updated.
A device driver or a system service might be damaged.
I use outlook express.it creates trouble today. i restarted my pc. then a notice showing " insufficient system resources exist in API" & i cant log i n my windows. when click ok Or close into it then...
hi dear
Insufficient system resources exist to complete the API
download update for windows xp (KB909095) and install it
http://www.microsoft.com/downloads/details.aspx?familyid=9D20F96A-A8D6-4627-89F7-787CD9B3852C&displaylang=en
if you do not able to install the fix
then boot your system with one boot cd and replace your page file with another one
2helpful
3answers
My computer shuts down in the middle of the game (Toontown)
Try to uninstall the program and reinstall it. Normally, this happens due to insufficient memory resources like video memory is insufficient and the system RAM.
Memory overload
Greetings mh5591,
What this means is there currently is not enough hard drive on the unit to boot up windows. If there's not enough free space on your hard drive, Windows won't open. Try accessing through Safe Mode and see if you can create the necessary room. Boot the system, start tapping F8, when the menu appears, select
Safe Mode and press enter.
I hope this helps.
Dorothy
Go Ahead. Use Us.
19helpful
8answers
Lsass.exe error insufficient system resources exist to complete the API. what can i do to fix that. thanks
how to remove ISASS.EXE SYSTAM ERROR INSUFFICIENT SYSTEM RESOURCES EXIST TO COMPLETE THE API
Insufficient Disk Space
nope..Quark is usually a dedicated system approach, where a computer is allocated to that work, solely. It's a fully operational system, and requires as many resources as you can give it. The memory's not the issue. You may want to increase the virtual memory on the disk to the highest level, if you are careful.
Top Sharp Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Ngoro
john h
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
