We have a hotpoint iced diamond fridge rlav21 but the problem is no matter how much you turn the thermostat down it just keeps on freezing everything
Can't solve your problem, but just to report we have exactly the same issue, a huge block of ice forms on the upper rear panel. The compressor seems to be running 24h, not matter where the 'thermostat' is set.
I suspect that there was/are a faulty batch of thermostats. Or (since there is no metal cooling plate to bolt it to) that the T/Stat probe has somehow come adrift from its correct sensing area and is not correctly sensing the temperature inside the fridge.
If I get to the bottom of the problem, I will re-post here.
