I have a semobi x2 mobile phone and want to access the internet from new zealand on a vodafone sim card. how do I do this? tried the wap and gprs settings but just get squares on a white screen ( like the page is in another language )
Here are a few things you need to know.
one, the default manufacture password is 1234 or 1122 or 0000. You may need to use it when you reset the phone.
Two, if it is a TV mobile, then you need to set the country area as “singapore” or “Indonessia”
and then search all the channels, you will get the best reception.
Three, to save the battery power.
1. turn off the Bluetooth function.
2. If you only use one Sim card, then turn off the second one. Just go to “settings” and then choose “Dual sim settings” and then select which one you want to turn off. (if you turn off one sim card and find out your current sim card can not get vodafone network signal, then you must turn off the wrong one, please change over)
Four, you may need to use WAP and PXT later. So, here are some instructions which may help.
1. go to the main screen, choose” Service”, then choose” data account”, then choose” GPRS”
2. Choose the first one.. Then, the screen will change to Edit manual.
3. now, choose Edit the “account name”. then change the data account to “Vodafone”. then choose the “option button” and you will see 1. done. 2. input method. then. choose” Done”
4. After you have done this, the screen will go back to the “Edit manual”
5. Now, you need edit the “APN”. just change the “APN” to “live.vodafone.com”. choose “option” and “done”
6. After done this, the screen will go back to the “Edit” screen again. Now, choose” Done” which is on you down right hand side. And it will ask for “save”, Choose “save”
7.Go back to the “wap” and then Choose” settings”
8. Choose” Edit profile”
9. now it will show 1. SIM1. 2. SIM2. Choose sim 1.
10. Choose the first one, After you click the first one, you will be able to see” 1. active profile” “2. edit profile”
11. Now choose “edit profile”
12. Now, choose 1. “Rename profile”, click “edit”. Change it to “vodafone”, then choose” done”
13. Then, edit the 2′home page” change it to :”http://live.vodafone.com” choose “option” “done” ( if everything you set up is in “Capital” then, you need put HTTP://LIVE.VODAFONE.COM. this is very important)
14. Then .choose “3 data account”. choose” GPRS”, choose the first one” Vodafone”.
15. Then, it will go back to the “edit profile”
16. then. choose “4 connection type” HTTP, then choose” OK”. Now you will be able to see “the proxy address”, then change it to”172.030.038.003′ and change the “proxy port” to “8080′. then choose” OK”
17. It will go back to the “edit profile”. then choose” Done” and it will ask to “save” just choose” yes”. Then choose” Avtive profile”
18. The same process to do on SIM 2 if you want to use the second sim card to surf internet. Now we just completed the vodafone live and do the PXT settings.
19. go back to main menu and choose “messages”. then “mms” then “message settings” then “server profile”
20. choose “sim 1′ and then the first profile then “edit profile”.
21. change name to “PXT vodafone” and “done”.
22. change “homepage” to “http://pxt.vodafone.net.nz/pxtsend”. (or HTTP://PXT.VODAFONE.NET.NZ/PXTSEND)
23. go to “connection type” and click “http”
24. change IP ADDRESS to “172.030.038.003′ and port to “8080′ then “done” and save all the changes.then activate profiles
25. Now Sim 1 pxt should be working.If you want SIM 2 to use PXT service, please change the settings following by the procesures again.
If you have Airtel or Tata Docomo as your mobile provider, we have confirmed reports of successfully using WhatsApp with a specific wireless access point configuration:
If you have Vodafone as your mobile provider, these steps may help:
If you have Idea as your mobile provider, you may be able to successfully use WhatsApp by following these steps:
