F-02(Long Drain)
HI. This code is an indication of a failed drain cycle(Long Drain Issue). Kindly, follow the steps below to address this issue further.
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
F02 is a long drain,press pause/cancel twice to clear the display make sure the drain hose isn't kinked or clogged with something, you can blow through the drain hose to see if it's clear but first clean the pump out,check the drain cleanout to see if it's clogged and check the boot that's on the drain hose near the pump,i've found alot of stuff in there too,this could have damaged the pump, now blow through the drain line,get the washer running and put it on drain,if the pump sounds funny or the water isn't pumping change the pump out,check to make sure power is going to pump before you change it if the pump isn't working at all,hope this helps
SOURCE: F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
