When I turn the LG 50pc1dra-ua on, there is a low beeping noise. After 8 seconds pass, it shuts off. No video. One second of audio occur just before it shuts down.
If the clear/stop key does not work, you can try throwing the circuit breaker, waiting 30 seconds, reengaging the breaker. Then try the clear key again. The LG models vary in control panel instructions and the user manuals I encounter don't mention shutting off the beeping. Rather, you are directed to make a call for service. On first installation or after a power failure, it is normal for flashing and beeps to appear. https://www.lg.com/us/support/video-tutorials/lg-range-pf-flashing-clock-CT00000303-1366750845305
This could be the power supply at 55 dollars or the LED back light strips that are about 80. Unless you know how to test them, it is a toss up. Most of the time it is the led strips though. http://www.shopjimmy.com/lg/55la6200-ua
Open the back panel. have a look at the power supply components. Look for abnormal component shapes. i have found bulged capacitors which cause this problem.
Please consult a professional technician, if you are a novice in this field.
Hello, not exactly sure what part you need to fix your tv. But, I have used a company named ShopJimmy.com in the past with great success. I included a link to your model page from their site. Hope that helps!
[email protected]
http://www.shopjimmy.com/catalogsearch/result/?q=50PC1DRA-UA
Your right its a power supply issue and what your hearing is capcitor pop or maybe even a fuse, Well if you know about eletronics sure the new psu is going to be $150 bucks
Have you recently changed any hardware or BIOS settings? Is it one beep for 8 seconds or 8 beeps? If it's 8 beeps then that indicates a bad video card. If you are not using the on board video then try re-seating the video board or try a different video board.
