Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My craftsman opener only goes one way.
I checked the limit switch and it is making contact but continues to try to drive past the limit.
    President:
  • 3,197 Answers
Your logic board is most likely bad.
Posted on Dec 07, 2009
SOURCE:
Garage door continues running even though sliding switch contacts end limit switch. Bends running bar. Only when closing- brown wire not broken
My guess is that the limit switch is not working or otherwise it would stop! Repair or replace the end limit switch. Do you have an OHM meter? if so OHM it out both open and closed if it does not change then it is bad.
Aug 22, 2011 | liftmaster Craftsman Garage Door Control...
Motor will not stop.
The wiring for the limit switch assembly is:
Yellow wire to the up limit contact
Gray wire to the center contact
Brown wire to the down limit contact
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Older garage door opener, 1/2 hp limit switch does not stop door in up position keeps trying and does not shut off?
If this is a Craftsman you need to remove the cover and you can then watch the limit switch assembly. If it is a Genie the up limit contact is probably broken
Oct 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman opener, limit switch not stopping motor.
try adjusting limit switch wheel to shut off just a little earlier by spinning wheel closer to limit if this doesnt help im afraid sometimes even new parts can be faulty you might try another replacement
Sep 30, 2009 | Electrical Supplies
Craftsman opener is not responding to limit switch on the down phase-- it continues down until the door goes full closed position and auto reverses. any suggestions? I have replaced the limit switch and...
On the side of the motor unit you will find the 'down limit' control. Turn this in the opposite direction of the arrow printed on the cover. It would be a good idea to take the cover off and watch the limit assembly while you are doing this to make sure it contacts before the door hits the floor.
Sep 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftman 1/2 hp chain drive , stuck in down motion
The thing to do is remove the cover and watch the limit switch assembly. You should be able to see how it is supposed to work and determine what is wrong. A small gear on the end of the shaft turns the limit switch assembly to make contact and turn off the motor in each direction. Something may be broken or out of place. There is also a possibility your logic board is bad especially if you have had electrical storms recently.
Jul 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a Craftsman 1/2 HP chain drive garage door opener.
You need to take the cover off the motor unit and watch how the limit switch assembly works. If the door is not stopping when the contacts make then you have a bad logic board.
Jun 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
CRAFTSMAN 1/2 HP OPENER
Ok well the best advise I can give you is to open up your opener case should be a 1/4 nut driver or a Philips head screw driver. Make sure to unplug it first. Once the case is off, find a reqtangle black box with three white plastic screws they are what controls the limits. Chances are they got knocked off wheny ou were putting in the gear. check to make sure the wires are hooked up and find the placement of the limits make sure they can touch each other. Little tip I do for my customs is get a piece of sand paper and rub it agaist the metal contacts for the limits only. (after time lift master openers bind up a film and dont stop where they supposed to.) If your still not sure how the limits work plus in the opener and run it make sure not to put your hands inside the opener and nothing esle is in the way. Then adjest the limits as needed. That should take care of you if not go ahead and make another post ill check back with you.
Feb 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster door won't reverse
check the relay in ur control board or replace it
check that the plastic cap in the rpm sensors doesnt stuck with any of them
check continuity in both limit switches..
check the capacitor terminals or the integrity of it
Feb 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
146 people viewed this question
Top Sears Building Materials Experts
Mike
Steve Allison
Steve Allison
Are you a Sears Building Material Expert? Answer questions, earn points and help others
