Honda 3000 IS. Output is only 99 to 100 volt. Unit works fine otherwise
Hmm.... try running it for a while with something plugged in that won't mind the voltage drop... like a light bulb..
The most common cause is the air/fuel mixture. But 1st I would suggest changing thew oil and spark plug, as old oil will thicken up and slow down the generator.
After that the next step would be to adjust the speed of the generator. Find the Carb, and adjust the black carb screw to speed it up. Do not have anything expensive plugged in, a light bulb etc.
If you need anymore advice or parts you can contact me athttp://www.GeneratorGuru.com
