Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
Mark Landry Posted on Jan 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Red line across top half of screen
Red lines across the top half of screen about half an inch apart. Red vertical line down the middle left side of the screen. I have a vertical red line in the middle of my MacBook Pro screen
  • 1 more comment
  • khulet229 Dec 25, 2008
    vertical red line running down screen.
    MacBook Pro 2.2 GHz Intel Core 2 Duo
  • Anonymous Feb 22, 2009
    i had left my laptop in my trunk in really cold weather overnight, and it was in sleep mode. when i turned it on, there was a red vertical line on the left side of the screen.
    the line went away after the computer warmed up (had it on and running for a few minutes). thank god, because i just bought it and i don't want an issue already.
  • Anonymous Mar 22, 2014
    A single, thin, purple line runs vertically on the left side of the screen. Is this a tool for something or a flaw in the screen?
Anonymous
Level 2:
Scholar:
  • Expert 163 Answers
  • Posted on Jan 17, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
163
Questions
Helped
104520
Points
301
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
  • Anonymous Jan 18, 2008
    Apologies.. I Meant NOT under warranty.. Whats the ammt of video RAM onboard? And the chipset please.. (Video)..
Lines vertical
These lines are called vertical retrace lines, and caused by the video output section; or improperly set screen voltage. All of these type of lines will be a little slanting type, across the screen all over, with an approximate one inch apart to each other. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Screen issues
I think better to replace the set as all this sounds like a light engine failing.
Panasonic plasma tv th42px8ob 2 inche vertical line showing
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
2answers
Thin red line across screen two inches for the top. Picture above line is good, picture below line has no color and double image.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out.....
1helpful
Red box half way down screen
I am getting re or blue lines running vertically on my Tv. They are not there all the time just now and then. Can I fix it with my remote or do I need a tech?
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
1helpful
4answers
My maxent 42" has green and red flashing pixels all across the screen, what is the problem?
Thanks
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
