Nokia 6300 Cellular Phone Logo
Posted on Dec 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Starting problem with Nokia 6300
Hi
My 6300 started taking longer and longer to turn on, since some time back. I ignored it due to high number of SMS in the phone. and now all of a sudden it just wont turn on, every time I do so ... it hangs up for 10-15 mins. after 10-15 mins the screen restores, but the moment I press some button it hangs again.
I'd appreicate your help in this regard
Anonymous
Level 2:
New Friend:
  • Expert 94 Answers
  • Posted on Dec 05, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
94
Questions
0
Helped
54875
Points
297
Delete some items from phn memory,format the card and also update the software from nokia,com
NOKIA 6300 not turning on
Connect the charger to your phone and plug it on the wall. If your phone start charging, now try to turn it on.
Otherwise take out the battery, place it back in, and try the above step again.
Both didn't work? It is a time to get your phone fixed.
My nokia 6300 gets switch Off and On itself, it continues to happen abt 4-5 times. If one switch it off and then switch it on, then it takes abt 7 minutes to start functioning. At times, it even gets...
hi
there will be virus in your memory card.please try to format the memory card.then format the phone with new OS. this will probably prevents hanging of your mobile.these hangings are happening due to virus programs.kindly be alert.
thank you
I cannot turn on my 6300 when i press the on button, my phone start blinking a few times then it goes black
Hi, there are two things you would need to check:
  1. The battery.
  2. VIRUS.
You can charge the battery for longer period of time, to see if the batter will power up the phone. If it doesn't , you will need to use another battery to see if it will power up the phone.
Virus might cause the phone to blink that way. After trying out with the battery,if no solution, that means you will to flash the phone.
Flashing the phone powers up a blinking or a dead phone due to VIRUS infection.
Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone.
Read and learn more about flashing and how to flash a phone on this link.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
I sent an international SMS from my Nokia 6300, the sms went but i never got the delivery report nor it's showing in my sent folder. Is it due the fact that SMS was very long...??? Please advise
first you go to menu, message, message setting. delivery report on. then you will get delivery report after you change settings. Thanks
tenzin
Due to much sms the cell restarts automatically
restore factory setting by code.12345.or else flash your phone
My Nokia 6300 fail to operate after an automatic shut off due to low level of battery. but soon after i recharge my battery and switch it on again, i realised my 6300 was unable to open the contact, sms,...
try to remove your memory card and try to open it again..Most of the time memory card is the cause of hard starting, reason is the the card is not inserted correctly.
just try it, no harm will be done to your unit
I want to change my Nokia 6300 front and back body panel
I m shahid working at Nokia Care, Bolangir, Orissa. In my opinion you must go to Nokia Care at Delhi. You will found the cabinate. But it is quite expensive. But try once, you must be satisfied. For further details contact me.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
