Epiphone Dot Electric Guitar Logo
Posted on Dec 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I fix the high action on the dot? - Epiphone Dot Electric Guitar
Anonymous
Level 2:
Scholar:
  • Expert 109 Answers
  • Posted on Dec 16, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
109
Questions
0
Helped
62112
Points
212
First, try lowering the bridge. Lower it as ow as you can without the strings buzzing excessively. Check the straightness of the neck. You can adjust the truss rod and put a very slight bow in the neck if low action results in too much string buzz in your case. The nut may also be too high but a simple bridge adjustment should do it.
2answers
High action martin java mahogany 00x1
To lower the action on an acoustic guitar:
Usually just the saddle needs reducing.
1. Remove strings (or you may be able to just loosen them). Remove saddle, sand down the bottom a little at a time. Restring and check action.
The action can be set as low as poss without any fret buzzing or note choking on all strings and on all frets.
2. Repeat 1
If the action remains too high then there are other techniques.
Later ...
Problem with truss rod on Epiphone SG Prophecy
i dont know your experiance level with this, but if it was me, i would take it to a professional, have them do it and explain to you how to do it.
Nov 23, 2012 • Music
Truss rod slippage
If the truss rod has broken loose, it is not user serviceable. This needs to go to a repir shop. The fretboard has to come off to fix this. The repair may be more than the value of the guitar.
3helpful
2answers
Peavey Pr-15 fuse blown, speaker not working. What is the fuse rating
Actually its pretty funny thing with those speakers is the "fuse" is Actually called a Lamp in this case. These are what they call a " Red Dot Fuse ". in all the years i've been doing this i've never thought to look up the value haha. Just have to know there are Red Dot lamps and Blue dots and No Dot. If you examine the LAMP you should see somewhere close to the ends ON THE GLASS a color dot of some kind. almost like someone painted it on there. Red Dot Lamp. any parts distributer for people like Harbinger, Peavey, and B52 will KNOW what your talking about
2answers
Had my guitar PLEK'd because we found out the frets were defective from the company, this was supposed to fix the problem of high action, still cant get the action low without it buzzing
Take it in for setup. Likely the truss rod or the bridge is out of adjustment. Wrong strings can also cause the problem. There are YouTube videos on guitar setup... I would NOT attempt truss rod adjustment yourself.
When I bend a note on the high E string past 19th fret there is a high almost feedback like sound almost immediatly after bending and the note cuts out, what's going on?
Check the height of your action on that string. It is possibly vibrating against the frets higher up. Try setting it slightly higher.
High action even though neck is straight. I have also messed with the bridge saddles and not much has changed except it gives fret buzz when i lower the saddles just a little bit. Is high action a common...
Sounds like you need to get it intonated. Take it to your local guitar shop tell them your problem and where you'd like your strings to sit or that straight neck of yours won't be like that for long.
Good Luck, Cody J
3helpful
2answers
How to lower the action on a b.c.rich warlock bronze series
To fix the action on your B.C.Rich Warlock, you need an Allen Wrench, or Hex key. There is a truss rod cover on your B.C.Rich's headstock. Just open it using a screwdriver and you will find the truss rod. Then adjust the action using the hex key.
check out more here -
http://www.squidoo.com/b-c-rich-warlock-set-up-and-fixing
2helpful
Top Epiphone Music Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
tednugentlives
tednugentlives
Level 1 Expert
Are you an Epiphone Music Expert? Answer questions, earn points and help others
