Paolo,
The VM is a very hard machine to work on. You have to start by taking off the battery. Then remove all the screws on the bottom of the case chassis. Once that is done, with the screen extended, carefully run a soft wood chisel or a fingernail around the machine, releasing the clamps on the side of the system holding the plastics together.
Once that is done, you will carefully have to pull away the bottom case from the rest of the system. That will expose your HD and memory.
