Tip & How-To about Heating & Cooling
Running your furnace out of heating oil is not that uncommon. There are many different things that can go wrong to cause you to run out. If this happens to you do not panic, you can get your oil burner running rather quickly. You just need to know what to do.
You forgot to order more heating oil for your heater and now you have run it out of oil. The first thing you need to do is find a container that will hold at least five gallons of liquid. A container that is approved for flammable liquids is always the best.
Next, locate the closest gas station or convenience store that sells either regular diesel, off road diesel, or kerosene. Any one of these will work to get you going. Make sure that you never use any type of gas in your oil burner!
You will need to add at least five gallons to get the level of the liquid in the fuel tank over the oil intake pipe so that you can prime the pump. When you get the fuel poured into the tank you should wait at least ten minutes to let the fuel settle before you try to light the burner. Dumping the new fuel into the tank with very little liquid in there will stir up the sludge in the bottom of the tank. If you try to pull oil into the burner while the sludge is suspended you will then create more problems.
When you have the fuel in the tank you can begin to start the burner. If you have a TigerLoop installed in your fuel line then just by pushing the reset button you can purge the air. With a couple of clicks of the reset button you will be heating again. If you do not have a TigerLoop but the burner pump has a two pipe system the oil pump will usually purge the air, but it may take a few resets to get it going. If you have only a single pipe system, then look for my tip on bleeding your pump.
Running your oil burner out of oil will sometimes happen. You can fix the problem if you know what you need to do. Usually this always happens on the coldest night of the year or on that holiday weekend when a service call to the heating oil company will cost you an arm and a leg just to get you warm again. Now you can get your family warm till you can get the tank your oil tank filled at a reasonable cost.
