Hard drive full, running xp ,drive is paritionedc,d dont need norton goast on d and it would give me 18 g more if i can do away with partition and make it all c.how is this done
To delete a partiition is quite easy in windows. but you will need a third party application like "partition magic" to merge two partitions together, this could be costly
The best advice I could give you is to back up all your information and reinstall your windows straight onto one partition. This will improve your overall speed and also probly also free more space by deleting unwanted programs, spam etc.
Regards
There are several ways to format in XP:
Note: WinXP will not let you mess with the boot partition or system partition since both contain items required to boot and run WinXP. Thus, you should use the install process to format system and boot drive.
Here is the easiest way to perform a "Clean Install" of XP:
Using
...and others I believe. But since this tutorial teaches a Clean Installation of XP, select "Clean Install".
Using Windows 98 Boot Disk:
Get yourself a Windows 98 boot-diskette with fdisk. Delete all partitions and THEN boot from the CD. If XP's setup finds formatted partitions, it proceeds without user intervention. If it doesn't find any, setup will prompt you for partitioning and formatting.
