Cold on drivers side and heat on passengers side, actuators working properly and blend doors are moving. Heatertreater is for piece of plastic on actuator motor. I moved blend door by hand after disconnecting actuator and works fine, both sides freezing when moved in opposite direction.
It sounds like the blend door is broke. Does it have dual climate controls. Check out heatertreater.net excellent product i have used on jeeps and is huge money/time saver.
Does the air blow as hard on the passenger side as on the driver side? If so, then it may be that the heater core is clogged and not flowing hot water through one side. Good luck.
Stuck air dam door. or broken knob on control. or cable feel of air door. don't work on dodges it may be a vacuum line that controls it? its sounds like it has heat but outside air is cooling it down to me.
We can hear a sloshing sound coming from inside the dash area. Also, the heater core hoses are hot like the core is working.
Where can I find the "air dam door" & how would I find if it is working/stuck/broken?
