Anonymous Posted on Dec 04, 2009
I have a kenwood compact hi-fi system xd-751 the 3
I have a kenwood compact hi-fi system xd-751.. the 3 disc draw won't open or play discs.. the table still turns though.. can anyone help please
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
819
Points
I have a Kenwood hi-fi system XD Series. the three disc draw won't open or play discs. The table shudders when on...can anyone please find a repairer in the adelaide district.
My dad has a kenwood multiple compact disc player dp-mh5 that the disc tray randomly won’t open on, any suggestions on what to try?
Hello Skye, the Kenwood Multiple Compact Disc Player DP-MH5 of your dad, has a problem with a strap inside the mechanism, I suggest you take it to a specialized technical service
If you have technical knowledge, I send you the link to download the service manual, on page 16, the breakdown of the mechanics appears and shows you the belt with the number 46, that is the one that you must replace
I also sent you the link to download the user manual
Greetings Franco Dosil
Hola Skye, la Kenwood Multiple Compact Disc Player DP-MH5 de tu papa, tiene un problema con una correa dentro del mecanismo, te sugiero que la lleves a un servicio tecnico especializado
Si tu tienes conocimientos tecnicos, te envio el link para descargar el manual de servicio, en la pagina 16, aparece el despiece de la mecanica y te muestra la correa con el numero 46, esa es la que debes reemplazar
Tambien te envio el link para descargar el manual de usuario
Saludos Franco Dosil
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Kenwood-DPMH-5-Service-Manual.pdf https://www.manualslib.com/manual/203920/Kenwood-Xd-8551.html?page=17
Lbt-117 compact hi fi system
Could be simply a dusty laser lens. Try a cleaning CD first.
After that, it could be that the laser assembly has low power output. Some decks have the range to increase the laser power, but it's only a temporary fix. The emissions are dying so the laser assembly will need to be replaced sooner of later..
Kenwood hi fi componenet system no play error for dvd-r disc
Is it a DVD-R or DVD+R disc?
comment says -R just wanted to clarify, alot of players have trouble playing the -R discs. If you have your booklet for system, it should say in there otherwise they usually put a little sticker label, by the DVD tray with what file formats and discs it will play.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
1helpful
I got a LG HI FI SYSTEM. DOES NOT READ DISC.
hello,
it is either the lense of the hi fi system that may be faulty, therefore, if that is the case you take it back to the dealer that sold it to you.
or probably the disc is not compatible with the HI-FI system.
Kenwood XD-A55 CD player shows 'no disc'
The first thing you got to do is clean the laser lens maybe is dirt,witha qtip wet with alcohol clean the lens then with the dry part clean the residues of alcohol good luck
RCA RS 1285 5 disk audio system won t show or play
When you turn on the unit the cd draw seams to open. I hear it making a noise like if it is trying to get ready to play. When you shut the draw it won't play, change tracts, or the disc thing to put in more disc wont work. Someone please help me
3helpful
Kenwood 10 disc changer
i have a sony mini Hi-Fi Component System MHC-GX470. I comes on, the Radio and Tape deck plays well. the CD Player says "mecha Error" and hangs. CAN YOU PLEASE HELP ME???
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
