I found a few websites that sell replacement mirrors for the Apollo Horizon 2 overhead projector. Here are some options:
Amazon.com: You can purchase a new mirror for your projector on Amazon.com for $29.99 .
OfficeSupply.com: This website sells a replacement mirror for the Apollo Horizon 2 overhead projector for $31.49 .
Staples: You can purchase a replacement mirror for your projector on Staples' website for $32.99
Does this projector have an automatic timer that doesn't allow it to turn on after a set number of hours (@ 1000)? If so, you may need to re-set the lamp-hour clock (as if you changed the lamp even though you didn't). Some machines require you to at least slide open the lamp cover to make it think that you changed it.
Hi! This is a pretty common problem with overhead projectors. At the top of the arm that's over the unit, there should be a lens unit. The unit needs to be rotated so that one lens points down, and one lens points towards the screen. Once the lens is rotated properly, the lens unit is moved up or down in order to focus. There's usually a knob to turn to move the lens up or down.
overheating. clean out the projector with canned air and check the fans for operation. reset the settings for factory default. if you replaced the lamp recently, reset the lamp timer through the menu.
