I got a m2n-mx mb ,and i use windows xp and the windows cannot recognized my usb ports.its a driver problem or something else?pls help
Reinstall your USB drivers:
Navigate to Device manager, find a branch named "USB Controllers" or similar
Right click the one thats the problem (or all of them if you dont know which), select Uninstall
Reboot your machine and windows will autodetect the USBs and reinstall their drivers
Check the BIOS and see if they are enabled...
Disable power management on the USB hub To preserve power, Microsoft Window XP tries to disable USB when a device is not used. Under certain circumstances this function does not work and may cause USB devices to fail to respond when called. To resolve this issue, disable power management on the USB hub by doing the following:
all my usb ports work but when I plug my realflight controller in it says it does not recognize the and shows no driver for this item but if I plug a 4 port powered usb in then the controller works why is this
Hi all, my Usb cannot be recognized when I plug either in front USB, orin the back side of my motherboard, I reinstalled windows severaltimes, but neither printer nor camera, and nor scanner does not work,if somebody had the same problem and then solved it please contact me,or post it hear, my email [email protected] Thanks beforhand !!!
Many of my USB devices can´t be identified (e.g. iPod, camera, internet modem etc.). I already tried to reinstal drivers for motherboard - unsuccessfully.
