Question about Onkyo TX-SR501 Receiver
My Onkyo HT-R510 will shut down after several
My Onkyo HT-R510 surround sound receiver will shut down after several hours of operation and the red standby light flashes. What could be causing this? This is a valed product!!!
    New Friend:
    Problem Solver:
  • 5 Answers
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
Posted on Feb 13, 2010
SOURCE:
Want to control my HT-R510 with my TV remote. Need Onkyo code to control this HT-R510
You should indicate you remote.
In any case, if code is not in your remote you should follow indications for No code
If you don't have a manual, look for one using google,and terms manual, make and model of your remote
Aug 26, 2015 | Onkyo Audio Players & Recorders
After turned on the power, the unit shuts down immidietly
There is a problem in either the power supply or amplifier output stages. The unit is programmed to shut down in such an event to protect other circuitry.
Using a schematic see if you can isolate the power going to the output stages. If unit stays on then the anomaly is in power amp stages. If it still shuts off problemo is in power supply - check diodes and capacitors.
Mar 12, 2015 | Onkyo Ht-r510 5.1 Channel 100 Watt Av...
Onkyo ht-rc180 standby light blinks will not start.i tryed factory reset, still blinks
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 24, 2014 | Onkyo Ht-Rc180 7.2-Channel A/V Surround...
Onkyo HT-R510 left side speaker garbled
Out put transister could be fried ,Or the speaker is blowin,
Nov 29, 2012 | Onkyo Ht-r510 600w 6.1 Dts Home Theatre...
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
I have an ONKYO HT-S3305 which transiently 'cuts-out' the sound - lasting only seconds (hooked up to TV/satellite HD receiver) Seems to start after about 1-2 hours after switching on. Not the signal...
It sounds to me that some part of the circuit possibly an IC is overheating after several hours and develops a fault.
This will be a very tricky thing to track down. So maybe best to take it to an authorised service agent.
Oct 15, 2017 | Onkyo HT-S3100 Receiver
Can the speakers surround sound work if the optical out is not red?
Yes.
There are several other methods for your surround sound channels to operate without your optical connection.
Jan 01, 2011 | Onkyo TX-DS939 Receiver
Selecting phono preamp for Onkyo HT-R510
The magnetic cartridge preamp should work with the turntable, as presumably it will have a magnetic cartridge in it. The only reason that the amp states "magnetic" is that some very old turntables have ceramic cartridges which should not be connected to that terminal. Even if the turntable had a "ceramic" it could be replaced with a magnetic one!
Mar 21, 2010 | Onkyo HT510 Receiver
Wireing
Consult HT-R500 operations manual for hook up
Feb 08, 2008 | Onkyo HTR500 Receiver
Onkyo TX-SR501 Receiver Logo
1,149 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
