Your printer needs to be reseted. Here's how to do it: Switch on the machine, holding down 0 & 8 buttons, type in 89,
press the green button, enter a 0, press green button again to accept
the new value. switch off & then just switch back on as normal. Hope it will work and solve your problem.
When the key of the digital keys and the [CLEAR/STOP] button are pressed simulta-neously, an error code (consisting of a letter of the alphabet and numbers) appears on the LED display. What is the error code? If "C4x" error code, perform 08-400, reset the value to "0".
C7 error is th\at no heating of the water has happened. check the heater (most likeley) also can be faulty relay on electronic. ntc fault, pressure switch or wiring to any of them.
This is a C05 error code. This means you have a fuser error. The fuser is the section that gets hot right where the paper exits the machine. Most common failure in the fuser unit is the thermal fuse. The repair requires removal and some dis-assembly of the fuser unit to replace the fuse. Also have to use a special reset procedure to clear the C05 code from the machine after repairs are made. Do you have access to a local repair shop that can repair this for you?
You can reset the C7 code, hold down 0&8 power machine up. Then push 87 & print, change the number to 0 with number keys press interupt key, then press 0&9 @ the same time to exit. This should clear the C7. Let me know if you need more help.
