Saeco Magic De Luxe Espresso Machine Logo
Posted on Dec 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have water in the discard container and wet grounds. They used to be dry brickets.
Anonymous
Level 3:
  • Master 1,089 Answers
  • Posted on Dec 08, 2009
Anonymous
Master
Level 3:
Answers
1089
Questions
0
Helped
521281
Points
4348
Hi
There are a couple of things that make wet grounds. One is a very coarse coffee. It should be like granulated sugar.
The second is your thumb screw is stripped, and needs to be replaced. Thumb screw holds the filter screen in in the brew head.
4answers
In fire fighting, what is the wet sprinkler and dry systems?
There were other systems as well like Halon, which is no longer used and CO2 systems, which I am not even sure if they still use either since they now have a water fog system that I am told works very well. Maybe I should investigate and see what they have come up with since I retired.
Apr 20, 2019 • Garden
1helpful
I have Tupperware drink container I put washing detergent in it left it for about 6 weeks.before using how can I get Omo smell out of container
Rinse it well with hot, soapy water and allow it to air dry.
Once it is dry, take some loosely-crumpled, dry paper towels or napkins and leave them in it for a week.
You could also either fill the container or put a box worth of baking soda into the container and leave it for a week. Discard the baking soda afterwards or use it to clean your toilet.
Either of these should eliminate or dramatically reduce any foul odor.
4answers
I would like to feed my cat canned food. What are the advantages of canned food over dry food?
Canned cat food has some advantages: it does not require as much additives, it contains morewater, it has higher amount of animal protein, and it contains much loweramount of carbohydrates than dried food.
Aug 01, 2012 • Cats
1helpful
2answers
Ice and water tastes funny after I installed a rubber water hose
Discard the first few batches of ice made by the ice maker. If new plumbingconnections are installed, discard the first few batches of ice. The plumbingsystem is flushing and may cause a bad taste or odd color. Discard ice stored in the bin for long periods of time. Wash the ice binwith warm water and mild dish detergent. Dry thoroughly before replacing thebin. Place foods in airtight containers to prevent the transfer of odors.Thanks and hope it's helpful.
Water and ice taste very bad in whirlpool side by side. Only a year old
Discard the first few batches of ice made by the ice maker. If new plumbingconnections are installed, discard the first few batches of ice. The plumbingsystem is flushing and may cause a bad taste or odd color. Discard ice stored in the bin for long periods of time. Wash the ice binwith warm water and mild dish detergent. Dry thoroughly before replacing thebin. Place foods in airtight containers to prevent the transfer of odors.Thanks.
I have a 5.5 hp craftsman 20 litre wet Dry vacum . I have lost the manual. & have 2 questions 1) how do I change to wet vacum from dry? Also could i use the wet mode with some water in it and let it...
# 1 myou just take the bag out make sure ytou sponge filter is in place athe top and turn it on the power switch just turns on ,machine ther is no wet dry switch just an empty bagless cannister is all you need make sure the ball outlet in vacumn is working it stops water from overfilling cannister # 2 just use the proper bag and attachment to vacumn up the drywall dust a good building supply store has special sanding attachments for vacumn so you can sand and vacumn at the same time
Dec 18, 2009 • Vacuums
DOES NOT VACUUM NOW
Several possible problems:
1) Did you clean the blue lower pickup container (dirty water) before putting it away?
Take out the pickup container and open it up, check the filter (under the little blue piece on top) and also open up the container itself and clean under the flapper on the "screen".
2) Look inside the housing and check the vac hose that goes from the front of the unit up to the rubber grommet where it goes into the lower pickup container. Is it clogged? If yes, take off the front pickup (the part the runs along the floor in front of the rotating brushes) and run a very narrow lint pickup brush (like for cleaning dryer vents) and clean out the hose. It works great.
3) Check the front pickup for clogs and clean
4) If you are trying to pick up water, make sure the setting is set to wet. If you are trying to use it as a vacuum, set it to dry.
Hope this helps.
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
