SETTING NOMA N1506 TIMER
Plug in timer – The letter C will Flash
TO SET CURRENT TIME:
Press Time Button – It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button – Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again – the letter E now flashes.
Press time button repeatedly until required ending time appears in the
window. (Note: a dot at the bottom right corner of the display
indicates P.M.hours).
Press Mode button and the display returns to the current time.
Programming is now complete. You may now plug in whatever needs to be
turned on. The device will turn on and off automatically every day at
the times you have just selected.
TO REVIEW THE PROGRAM
Press time button – Displays successively, for 1-2 seconds each: P,
starting hour and E, ending hour. Then returns to show the current
time..
TO CHANGE YOUR PROGRAM
Unplug the timer, which will discontinue the current program. After 10
seconds, plug it in again and proceed to set current time. Then
continue with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing the Mode button at any time will turn on the devices plugged
into the timer. The display will indicate the letter O. The devices
will remain on until the ending time of the daily program. To return
the timer to the automatic mode prior to that hour, press the Mode
button again. The display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off.
SOURCE: Model N1506, I need Operation instructions for
N1505 timer manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
SOURCE: I need the user guide for a Woods Outdoor Timer
Woods timers and manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html
N1502 manual:
http://waterheatertimer.org/pdf/Woods-49103-N1502-manual.pdf
N1506 manual:
N1506 written instructions
http://www.fixya.com/support/t6964404-set
SOURCE: How do I set my
You can get the manual on the link below.
