Hello.
I am a Support Engineer with Xerox Scanners.
We do not make a scanner with the model number 636.
If you are referring to the DocuMate 632, the drive gear on the ADF roller is available in the roller replacement kit (attached to the ADF roller, not separately). You can order that kit here.
On the other hand, if you are referring to one of the gears in the ADF housing, the device will need to be sent in for service.
If you continue to experience trouble or have any questions, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
The only place you can buy this is from xerox direct. Please locate your nearest xerox dealer and obtain a part number from them:)
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
