You need the removal tool that is like a two pronged fork, try using a pair of pliers and bending the end of these tools inward slightly about 5mm from the ends, this will push the ford clips inwards that exrtra bit to enable it to release. I used to get Ford garages sending cars to me for removal as i knew the little trick needed. Hope this helps
Dan
Testimonial: "Thank you! Fast response and really helpful! "
Recently purchased this decode software for my business
and it seems to be doing very well. I ran your serial number and recieved a
code of 0692. Would be grateful if you would let me know either way if this
code worked as I want to keep track and make sure I got my money's worth buying
this software. You can reply/comment here or email me directly at [email protected].
Thanks and I hope this works for you....
code of 8533. Would be grateful if you would let me know either way if this
