2001 Nissan Xterra Logo
Posted on Dec 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Looking for distributor wire diagram
I have a 2001 nissan xterra. i changed plugs and wires. the wires are going to the right plugs but i think i have not routed the wires properly. could that be the cause of car still shaking
David Burbee
Level 3:
  • Nissan Master 1,871 Answers
  • Posted on Dec 05, 2009
David Burbee
Nissan Master
Level 3:
Answers
1871
Questions
Helped
1056684
Points
1009
If your engine is a four cylinder, the firing order is as follows; from left to right on the block..1-2-3-4...look at the top of the distributor cap: counter clockwise from #1, the order is...1-3-4-2. If your engine is a six cylinder, face the front of the engine...left bank is: 1-3-5...right bank is: 2-4-6...look at top of distributor cap starting with #1...read counter clockwise...1-2-3-4-5-6. Let me know how you make out. Master [email protected]
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
3answers
Why would my 2003 Nissan Xterra A/C blower and radio lose power 2 days ago?
Question edited for clarity.
Question moved to model category.
There are three fuses and a relay that cover the blower. Radio probably has an inline fuse, but they are also monitored by the Body control Module.
Nissan Xterra (WD22; 1999-2004) fuses and relays
https://fuse-box.info > nissan > nissan-xterra-wd22-199...
Fuse box diagram - Here you will find fuse box diagrams of Nissan Xterra 1999, 2000, 2001, 2002, 2003 and 2004, get information about the location of the ...
Changed distributor in 2001 nissan xterra now oil light flickers
Sounds like you may have accidentally pulled the wire loose on the oil pressure switch. Just check it to see if it's tight and not broken or stretched..Always try easiest fix first..
2answers
MY NISSAN XTERRA SHAKES VIOLENTLY AND RATTLES WHEN I START IT, THEN IT DIES WHEN YOU PUT IT IN DRIVE
-There are couple things cause that.
-Check spark plug wire, spark plug, compression, fuel pressure and
injectors.
Good luck
Mai
Xterra distributor
More likely bad spark plug wires
2answers
Location for camshaft sensor for 2003 nissan xterra
We're is the camshaft sensors on a 2002 Nissan Xterra SE.. trying to replace both sensors
My nissan xterra 2000 v6 right side cylinder plug is having black fluffy substance stuck on the plug
Sounds like carbon fouling. Easy fix is run an aggressive fuel injector cleaner as recommended by your local parts store through the gas tank. Also ensure that spark plug wire is firmly attached. If you took the plug out-you know it is a pain to get to it! A easy way to see is to start motor and idle, pull #6 wire off at distributor when it should be attached to plug and see if the idle changes. If it doesn't, the wire is not plugged on the spark plug or the rotor/distributor may be faulty.
Another more difficult task may be the removal and replacement of the fuel injectors them selves (or cleaning by a specialty shop). Good Luck!
6helpful
2answers
P0300 (random misfire) code
nissan xterra codigo p0300 random misfire cual es el problema que devo de hacer para areglarlo
Where does the flasher relay go on a 2002 nissan exterra?
I have been searching for this same answer with little to no luck. It appears that on 2001, it's up above the drivers side brake pedal. However, I could not find it there. The wiring diagram I looked at showed it to be literally in the middle of the wiring harness, (behind the stereo). I have not had the gumption to try and find it, but that's where it appears to be. I love my Xterra, but hate that the company sees fit to put an essential relay well out of reach. There is no earthly reason this relay is not "plug-n-play" right around the fuse panel...Totally stupid...
2001 nissan xterra will not start without jump
Either he's talking about the field wire plug on the alternator or the battery positive feed wire , field wire is usually a two wire plug and the battery wire is single large wire around 8 gage or so. look for loose connection at either of these wire locations...
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
