Blackberry curve 8330 usb port is damaged how to transfer my contacts to the replacement phone?
Look in the charging port (on the phone) and see if all of the pins are intact. You should see a total of 5 gold pins. If one of them is broken or bent, then the port may need replaced. Also check the moisture indicator in the battery compartment. If it is red then the phone may have water damage and will have to be opened cleaned and components tested.
