Sorry I cannot see the model number.But I've been informed that the pressure relief valve is a goner.Since there is a leak that drips onto the electrical switch does that mean the tank could be over full to cause this?How can I drain the tank without flooding the bathroom. Is the pressure relief valve in the top of the unit where the water was spraying out?
Thank you.
The T&P valve (temperature and pressure) relief valve is suppose to have a 3/4 in drain line threaded into it .This line should have ran to a trapped drain or possibly to the outside of the house. A water heater cannot over fill. To drain your water heater run a garden hose to the outside or to the lowest drain you have nearby.If its still wet be carfull not to get shocked,Attach the garden hose to the drain valve located towards the bottom of the water heater. turn the valve on. If water dosnt come out of the other end of the hose,youll have to see if you can run a peice of wire through the valve into the water heater to get it to drain. This can somtimes be a real problem . I usually leave the water on when i first connect the hose to the drain valve. This allows the water pressure to flush the sedament out of the bottom of the water heater.
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
