The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!#@EWSF
I have held the bake key to get the E0 F2 error code and am unable to get this code . Everything works on the oven but the self clean mode . The door just wont latch . Any help ?????
Thank you. I called Whirlpool and tried all kinds of things, but it was your suggestion that resolved the problem, along with gently shifting the latch manually.
