ION TTUSB10 turntable - no sound, no recording. It is plugged into Toshiba laptop, via control panel: sounds and audio devices properties, audio tab, sound playback and sound recording set to Realtek AC97 Audio only other option is USB Audio Codec. I don't have external speakers. I downloaded ITunes and I can see a recording bar via ezconverter but there is not movement on the recording bars. The other setting is "line" on the back of turntable. Operating system is XP home. Thanks!
Maybe the output is not good enough for line in on laptop try mic in, then double click the sound icon down bottom right where time is, goto options, properties, then recording inside of recording make sure all boxes are ticked so you have all options like mic wave stereo mix line and so on, click ok, now make sure what ever you have the turn tables pluged into is selected as your recording device and not muted try again, once this is all ok ., it should work. hope this helps. also make sure your software you use to record is also set up same. take care
Testimonial: "Thanks that solved it!"
