Televison & Video Logo
Posted on Jan 17, 2008
Sanyo TV stuck on video channel
I have a Sanyo model # DS35590. I put it on video1 channel to watch a dvd. My kids lost the remote before I could take it off the video channel. Now I can not change it. I tried from the menu button, and nothing. I also tried programming a universal remote to the tv, and still nothing. Please help
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 25, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1453
Points
Sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
Channel stuck on video1
if the remote has an input key or a source key press it that should help if not i am sorry.
Cannot get the tv into 'video1' (or ' video2') mode
Unfortunately you need the original remote. There is still a good chance you can find a Sanyo universal remote. Check your local Circuit city or Super K mart or Walmart and look inthe electronics sections. I have often seen the Sanyo universal remote! And yes it will have the options you are looking for. Good Luck!
20helpful
Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
2helpful
I can't switch to aux/video without my remote.
not really sure about this but if you put a disk in then run auto scan for your channels,long shot but worth a try.
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Tv stuck on video
most universal remotes will not operate menu fuctions or allow input selections. try using channel down buttton on tv . go all the way down to channel two then go down again to see if video1 or 2 comes up. if not access menu functions on front panel go to input select enter in manually mch
Sanyo tv stuck on "video 2"
I had the same problem and had to buy a new remote. Just Google Sanyo remote--it's the more expensive one with more buttons. Good luck.
39helpful
13answers
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
3answers
Sanyo lost remote
I had the same problem. Just got a DVD player and hooked it up and nothing. I got the Sanyo TV from a relative. Anyway channel 3,4 not work and when I go 00 still nothing. Then I pressed Input on the remote and a blue screen popped up. Turn on the dvd and now it works with channel 4. So I think any remote will work just put the tv to channel 4 and press input on the remote.
1helpful
6answers
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
