When i connect my archos 604 wifi i get a message that the usb device is not recognized and that it might have malfunctioned how can i fix this?
SOURCE: archos 605 usb connection problem
its possible you could have picked up a virus that is making unauthorized changes to your pc. happened to me. had to reboot pc to original factory settings.
SOURCE: Archos 604 wifi usb connection problem...
Okay, I just started reading your problem and started freaking out because it was happening to me and I suddenly thought that I would have to replace it. But luckily, my only problem was that I needed to prop-up my archos while it was plugged in. I would think that somewhere down the line, me and you have both knocked something loose in the connector. Luck to you, cheers.
SOURCE: Archos 604 Wifi Recovery Code 2
hello everybody, i had this same problem with my archos 604 wifi but thankx to someone on another forum i fixed it. it is really easy:
first you take the battery off, then you unscrew the 4 or 6 screw on the sides of the hard drive, then you lift the lid and then the hard drive, VERY CAREFULLY, Then you will see the problem : the little black plug conected through a ribbon to the hard drive is not plugged correctly or it is completely unpluged from the white socket. even if it is not un plugged just make sure it's tight, put everything back together and it should work just fine. ( IT IS A LITTLE DIFFICUL TO SCREW IT BACK TOGETHER BUT YOU"LL GET IT RIGHT) it is a weird problem. but it is easily fixed.
i hope that helps, bye
SOURCE: PC no longer recognizes my Archos 605
I had the same problem with my Archos 605 and here's how I fixed it....
Right click on My Computer, then click on Properties. Under the Hardware tab click on Device Manager. My Archos was shown under Portable Devices but with an exclamation point next to it. I right clicked on Archos 605 wifi and then clicked on Update Driver. This updated the MTP driver and now everything is working fine.
in the archos....select SYSTEM....change windows media player to PC Hard Drive and this worked for me
