Tip & How-To about Computers & Internet
Hidden Back-up utility
Win XP Tip,
Insert your windows XP disc into your PC.
Click exit if your installation screen comes up.
Now go too your CD drive in *My Computer*. Right-click and select open.
Choose VALUE ADD\MSFT\NT BACK-UP FILE.
In the *files of type* drop down list be sure that *select all files* is on.
Click on the NTBACK-UP.msi file and click okay.
Click the finish button and now go over too the start button\ALL PROGRAMS\ACCESSORIES\SYSTEM TOOLS\ and there it is now.. BACK-UP FILES...
Great little tool that Microsoft never should have hidden.
Win XP Tip, Rename Multiple Files
A new, small, neat feature for winXP deals with renaming files. I personally have always wanted the OS to include a way to do a mass file renaming on a bunch of files. You can now rename multiple files at once in WinXP. Its real simple:
1. Select several files in Explorer, press F2 and rename one of those files to something else. All the selected files get renamed to the new file name (plus a number added to the end).
2. Thats it. Simple huh.
I would recommend that you only have the files you want to rename in the directory your working in. I would also recommend that until you get used to this neat little trick that you save copies of the files in a safe location while your getting the hang of it.
Ever wonder what's going on behind that splash screen? Well, now you can find out!
Right click My Computer, Properties, Advanced, Startup and Recovery, Edit. Edit BOOT.INI. Add "/SOS" right after "/fastdetect" with a space between. The line will look something like this:
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /SOS
. Then you're finished. The first part, multi(0)..... may not be the same on your machine. Upon restarting, the splash screen will be gone. It can be re-enabled by removing the new switch.
Computers & Internet Logo
I have a Printmaster Platinum 17 set of 4 discs. Which one do I load first ? Install CD or programme CD. Not having any luck. Help please .
Complete these steps:
  1. Close all programs and windows to return to the desktop.
  2. Insert the Install disc into the proper drive.
  3. Double-click the My Computer icon. For Windows® XP, click the Start button and choose My Computer if needed.
  4. Right-click the drive containing the program Install disc and choose Open from the menu that appears.
  5. Double-click the Setup folder.
  6. Double-click the SETUP.EXE or Setup file to begin the installation.
  7. Click Next in the window that appears.
  8. Select Modify from the list of available options and click Next.
  9. Click the button to the left of each heading and select "This feature, and all its subfeatures, will be installed on the local hard drive."
  10. Repeat Step 9 for each component that appears.
  11. Click Next.
  12. Click Install to continue the installation.
  13. For the CD version, when prompted to insert another CD, remove the current disc from the CD-ROM drive and insert the requested CD.
  14. Allow sufficient time for the drive to read the disc and click OK to continue.
  15. When the message appears indicating that the installation is complete, click Finish to exit the installation.
  16. Remove the disc and launch and use the program.
How to Install Window XP with Vista
hi first C:\ Drive in Windows XP Install Complete & D:\ in Windows Vista Install & Enjoy. or Any Problem call me Deepak Kulkarni System,Surat 91-9898726758.
3answers
can i somehow just re install xp to solve my black screen, i did safe mode and disk check
Yes, you can re-install win xp, just follow this procedure- 1) As you turn on your laptop, start pressing "delete" button.Press it how many times you can. 2) After pressing the button.A blue screen will appear. 3) In that go to BIOS option. 4) In that option you will find and option named 'first boot' or similar like that. 5) Click on that option and change it to cd-rom. 6) save the settings and exit. 7) Then insert the win xp cd, before turning on your laptop. 8) Your laptop will automatically recognize the win xp cd on startup. After the cd is read by your laptop. 9) An option will appear "press any key to continue" or similar like that. 10) Press any key. And you will automatically will be taken to win xp installation window. 11) Press 'enter' to install win xp. 12) Then a confirmation window will appear. Check whatever you want to do to your laptop.
NOTE- installing win xp again will cause you your saved data lost. if you dont want to loose your data then just format 'c' drive of your laptop.
enjoy!! THANK YOU
win xp prof. again &again re starting problum
if the system was able to enter the desktop and restarts...once possible cause is a virus...scan the pc via safemode or reinstall windows.
but if it didn't enter the OS desktop...cause might be the boot loader or MBR is damage..
worth a try:
Run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3. If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5. At the command prompt, type this commands one at a time.
FIXMBR C:
FIXBOOT C:
COPY [CDDRIVE]:\I386\NTLDR C:\
COPY [CDDRIVE]:\I386\NTDETECT.COM C:\
BOOTCFG /rebuild
6. To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Grand Canyon Tech
Grand Canyon Tech
