There are two different dome lights in the supercrew one is connected to the garage door opener and sunglass holder other wise known as map lights. to get these out just simply pull the unit and the blubs unscrew from the back insert the new blubs and replace the unit. the other type depends on the model of f150 you have one is the normal dome light in witch you just pop the cover off and replace the light. the other is just like the front map light where you just pull the unit out and replace the bulbs the same way.
