Question about GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer
My GE deep freezer seems to be getting warmer. There only seems to be a freezer sensor panel. Does this mean that the sensor is broken or is there another way to get the freezer back to a deep freeze?
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezermy GE deep freezer seems to be getting warmer. - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 12, 2010
SOURCE:
STANDING WATER UNDER DELI TRAY
Try going further than defrost and draining the hose. There is gunk that builds up and you need to clean that out. Use a pipe cleaner(the fuzzy wires used mostly for art projects. They actually can clean pipes and water lines!!) Also, you can pick up a pack of pellets used for breaking down the "gunk" build up.
Mar 06, 2014 | GE Profile : PFSF6PKXWW 25.5 cu.ft. Bottom...
Refrigerator not cold
You say refrigerator SIDE not cold? You would expect the outside panels of a refrigerator to be around room temperature or warmer as the fridge removes heat from inside the cabinet and expels it outside. If you mean the inside of the fridge is not cold then check the door seals are sealing correctly around the door frame. You could also check that there is nothing inside the fridge protruding and therefore inhibiting the closure of the door correctly.
Jan 04, 2014 | GE 20 CFT GSE20JEWF BB BLACK COLOR SIDE BY...
Have upright frost free freezer alarm is going off about once or twice a day.Put a thermometer it is around 20 degrees I mute the al;arm and it beeps again and again after several hours. looked to clean...
Hi most deep freezers operate at 0 dergrees. your model may have 2 temp zones. 0 or 20 deg.I'm gessind that your sensor is going off when the defroster is on to melt ice (defrosting). Lower the setting. monitor and repeat as needed. if it continues you may need to replace the unit or ad freon. If the unit is over 13 years ge a new one.
Jul 21, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My deep freeze locks on its own. We dont have a
nothing to do with temp changes. only to do with a broken lock mechanism.
Jul 26, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
How does the control panel work? low numbers warm etc?? I inherited my partners mothers fridge freezer, unfortunatly it didn't include the instrution book,I have had it running on number 2 but it seems to...
Typically the larger the number the colder the setting. Is there an arrow on the knob that points to the left or right that says "warmer" or "colder" I also question your comment "freeze too much" because this is a freezer only, it will not keep things "cool" if you turn it up enough. If you mean there is frost on everything that is humidity and not the freezers fault.
Jun 03, 2010 | Kelvinator 12 cu. ft. / 340 liter Chest...
Just bought a used GE chest freezer model FH5DSAWH from friends. Brought it home plugged it in and it doesn't get cold. Can hear it running and the compressor gets hot. Any ideas? Was told it worked great....
your ptc overload relay on the compressor is bad,unplug it off the compressor and get a replacement at an appliance parts store,plug in the replacement and this will solve your problem
Apr 27, 2010 | GE 14.8 cu. ft. / 419 liter Chest Freezer...
Fridgeaire upright freezer is getting warmer and warmer.How do I
there is no way of cleaning the coils.there maybe a problem with the compressor.you should hear a fan running inside the freezer when it is in the cooling cycle and the compresor is running if you do not here the fan running this could cause a cooling issue and the evaporator could be building up with ice.
check the rear of the freezer to see if there is any ice build up.
Jan 18, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
We've got a GE American Fridge Freezer. 12 years
time to get a new freezer. check the floor under the freezer for coolant leakage, if none the compressor is ready to deep 6...
Nov 07, 2009 | General Electric Chest Freezer FCM5SU
Outside of chest freezer gets hot
it is normal for outside to get hot. that is where the condensor coils are located. if unit is working don't worry.
Jul 26, 2009 | GE Freezers
Freezer/refrigerator
Refrigerators with an evaporator (called a humid plate on this type of refrigerator) in the refrigerator section are called a semi-automatic defrost. This means that the freezer section occasionally needs defrosting but the refrigerator section defrosts by a means called "heat leakage defrost". How it should work....
the cold control, (the electrical device under the dial), leaves the compressor off for long enough for the plate to melt off each cycle.
If yours is not melting off perhaps you have a faulty control or you have it set too high. hope this help
Oct 07, 2008 | Frigidaire Freezer Refrigeration White...
GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer Logo
161 people viewed this question
Top GE Freezers Experts
craig nesmith
Level 1 Expert
Gil Shultz
Jay Finke
Jay Finke
Are you a GE Freezer Expert? Answer questions, earn points and help others
