Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. http://electronicshelponline.blogspot.com/
If you wish to get its original remote control, you have to contact the authorized service center for Element. If you wish to buy one universal remote control, you must first check out, which brand remote control have setup codes to Element TV. Setup code list will be attached to every universal remote control. If you wish to get more details, check the site linked
below. Pull up older posts there. Setup code list and setup proceedings to
many popular brand remote controls are given. Two digit, three digit, four
digit and five digit setup code list to different models remote controls are
given. If you search the site in Timeslide
option, which can be selected from the drop down list at the top left of the
display window, it will be easy to locate the related post. You can also do a search by type in the
brand name and model number to your device into its search box at the top right
of display window. http://electronicshelponline.blogspot.com/
If you have the owner manual for the remote try the codes listed or look to see if that remote has a search mode that allows you to try every code in it one at a time.
Please reset the codes and try again. You must replace the batteries by new ones type alkaline b) clean the contacts batteries c) retight the spring contacts batteries with pliers d) open the remote control for clena the keypad switch from dirty, dust, oxide, bad contacts or open , remember they send infrared signal from Syscon to the microncontroler Receiver. see the blck..d go to the next web pages, give your model, mark. www.remotecodelist.com + remotes.com God bless you
one of the batteries was not making proper contact and was loose,had to gently stretch spring contact out to make it stay in place .kept dislodging itself,so far so good.thanks
