SOURCE: "UE" error code LG washer wm0642hw
This is an Imbalance code. Your issue may be with:
Try adjusting the load size, and make sure the unit is level.
SOURCE: Getting a UE code on
Hello there
The UE ERROR CODE
UE
- Unbalance switch error
Unbalanced
load is sensed three times during a spin operation.
Open
lid. Rebalance laundry load and close lid.
· Check wiring harness
· Check unbalance switch
· Check circuit board Normally this turns out to be the unbalance switch that has failed and needs to be replaced so i would have this checked first.
If you have a warranty on this machine still you should be able to use it ok?
Hope this is very helpful or you.
Best regards Mike
SOURCE: my lg front load washer
Hi
Thanks
for using FixYa. UE is a Imbalance error which is cause due to any of the
following:
The load is too small.
The appliance is tilted.
Laundry is gathered to one side.
• Non distributable things are put into the
drum.
Please do accept the solution if the issue is
resolved or post a comment for further assistance.
Thanks
Rylee
SOURCE: WM1814CW Front Load Washer: UE error code on display...
UE is Imbalance error..Redistribute the load or you may have tried to wash something which will not 'spread' enough to balance the load...Nomess
SOURCE: LG washer Model # WM1814CW problem code UE
UE=Imbalance error
load too small
appliance tilted
laundry clumped to one side
non distributable object in tub
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
I had the UE error come on my wash machine panel. I just got my new machine last week and only two loads were run through.
There were only 4 pieces of clothing in the unit.
Why would I be receiving this error message with an uncompleted wash load.
